RE: 9caf range check
Hello Again
I fired up the plane again and did a quick range check with the antenna all the way in. I had well over 100 feet, maybe 125, and ran out of line of sight room, with no problem. I'm running a CH ignition so I was concerned about RF noise. I'm still concerned if running the Tx with the antenna in will cause any problems.
Sam
