RCU Forums - View Single Post - ESC causing radio interference
Old 11-19-2005 | 09:51 AM
pemiller's Avatar
pemiller
Default RE: ESC causing radio interference
Wrap the aluminum foil strip around the plastic wrap cocoon several times; crimp the ends around the leads. You can tape the aluminum closed, too.
Good luck. Let me know if this works for you!
Cheers.
/pem
ID:	356833   Click image for larger version
