RCU Forums - View Single Post - BVM EZ Air install question?????
Old 11-19-2005 | 10:44 AM
DrScoles's Avatar
DrScoles
My Feedback: (18)
Default BVM EZ Air install question?????
I did one wing last night with the EZ air... Haven't had a chance to test it yet for leaks... My question is, should they be rigidly mounted? In looking at them, it seems like it might be a good idea for them to be passively mounted... My concern is that when the wing is under load, its gonna flex and air will leak... I mounted the female side to the fuse via a plywood plate and aeropoxy... Male ends are in wing with just a drop of ca...... Will glue permanently once I find out the answer to my question. I know I have them lined up exactly, with no side load on them whatsoever.... Not sure that will be the case in flight or going over a bumpy grass field.......
Any ideas???
Thanks, Mike
