RE: Comp Bobcat aileron throws
Joel,
The "up"aileron end point adjustment should be 3/4" measured at the outboard end of the aileron relative to the wing tip. This dimension is found on the BVM website within the PDF file instructions for setting up the "Crow" feature for the ailerons and flaps.
I recommend the "Crow" setup heartily...I am using it on my KingCat, and have found it to be a helpful feature in the landing pattern.
If you choose dual rates instead of "Crow", use the 3/4" dimension as a starting point for high rate. Recommended throws are always a safe starting point.
Harley Condra
BVM REP
JetCat REP
