 Comp Bobcat aileron throws >
Old 11-19-2005 | 10:17 AM
My Feedback: (20)
Default Comp Bobcat aileron throws
Anybody know what the low/high rate aileron control throws are for the Comp Bobcat? My plans/manual doesn't show it.
Thanks.
Old 11-19-2005 | 11:20 AM
Default RE: Comp Bobcat aileron throws
Joel,
The "up"aileron end point adjustment should be 3/4" measured at the outboard end of the aileron relative to the wing tip. This dimension is found on the BVM website within the PDF file instructions for setting up the "Crow" feature for the ailerons and flaps.
I recommend the "Crow" setup heartily...I am using it on my KingCat, and have found it to be a helpful feature in the landing pattern.
If you choose dual rates instead of "Crow", use the 3/4" dimension as a starting point for high rate. Recommended throws are always a safe starting point.
Harley Condra
BVM REP
JetCat REP
Old 11-19-2005 | 05:20 PM
Guest
My Feedback: (73)
just to clarify, crow has nothing to do with low or hight rates .... crow lessens lift on the wing for a more predictable landing, preventing the plane from "floating on" or bouncing (on a bad landing ) on landing. On full rates it feels jutst fine with 10-15 % negative expo ... i never used dual rates on mine, but i would say if you want low rates to smooth flying at higher speeds, set to like 78 - 80% of the full setting ..
Wojtek
Old 11-19-2005 | 08:20 PM
ghost_rider's Avatar
My Feedback: (20)
ORIGINAL: wojtek
On full rates it feels jutst fine with 10-15 % negative expo ...Wojtek
Hmmmmmmm........ negative expo?. You must be using the radio that starts with "F".
Old 11-19-2005 | 08:32 PM
Guest
My Feedback: (73)
lol, im just used to it being always "negative" from my Fu**** radio ... I do in fact use a 10x for my jets however ( well, most ) ... to clarify, i was refering to the expo that softens out response around center stick
Wojtek
