RE: Can this be corrected??
The epoxied section can be removed by using a heat gun to melt the glue. apply the heat directly to the glue joint on both side of the fuse, be patient and work slowly. if you work the heat slowly you'll be able to tell when the glue is softening, and the part can be removed with no damage. clean all of the epoxy from both parts.
Egor
