Hog-Bipe Farmer
After reading several post on the hog bipe I couldn't wait to find one. I was lucky enough to find one at a local swap meet. I have visited fubarhill and read all the advise on what to change and not to change. I plan on putting a saito 100 in the front but would like to find a cowl to cover it. Any suggestions on were to find one that will fit. I also like the ideal of the two servos in the wing. Is this two in each wing or just two on the bottom wing? Has anyone tried two in each wing or is this needed? I'm new to tail draggers, I like the sound of moving the gear forward. Not real clear on the distance. Is the measure from the nose or the front of the wing? With the saito 100 will I need to add much weight to the tail if any? I plane to balance with the radio gear if possible. Any comments or advise would be appreciated.
