RCU Forums - View Single Post - BT32 Engine Mount
Old 11-19-2005 | 11:42 PM
OldCoot
My Feedback: (47)
Default BT32 Engine Mount
When mounting my engine I noticed that the right mount is slightly shorter (about 3/16) than the left which causes about 1.5 degrees of right thrust offset.
Is this correct ?? Just checking to see if the offset is supposed to be built in.
There is not any play in the mounting holes that would cause this and the mounts will only fit on the proper side of the engine so they are correct.
This would also dictate that the engine always be mounted inverted unless you shim between the mount and the firewall plate.
Dan
