RE: Genesis basic kit (Electric build)
Very impressive Steve! You're really cranking along on that plane.
Keep the pictures and descriptions coming, these are some of the best mounting pictures I've seen. It's very interesting how you mounted your motor. Did you use this approach in your other electrics?
Why did you go with the RTV in front, for vibration absorption?
It looks like the rear motor support just BARLEY is over the motor, why didn't you slide it up a bit more to make sure it doesn't slip out?
Could you tell us a little more about the carbon fiber flex plate? What are the properties of this material that convinced you to use it?
Last question, could you elaborate a bit more on the differences between the C50 XL14 and XL13.
Thanks for documenting your progress, it's REALLY helpful!
Keith B
