RE: 26 cc 4 cycle
Hi Brian,
Thanks for the pictures. I havn't run it yet with this exhust stack. It is about the same size as the port and very short. Is that the stock carb? Mine uses a drum type 9mm carb. I have an 11mm drun carb from a Toro that I want to try. I think that I need to add a spring because of the single pulse of the four cycle.
Dave
