RCU Forums - View Single Post - Please help me tune this engine,
Old 11-21-2005 | 10:32 PM
silverman1
Default RE: Please help me tune this engine,
I got the exact settings for you from my 24.7 manual for my XFactor Again 3 turns Out from lighty seated on the Low spd BUT: (Do this setting with the throttle slide pulled to the wide open position of course without the motor running, this is how you set the initial low spd setting.) these instructions are per XTM Maual. High spd needle 3 turns out from lightly seated.
These are initial settings, I knew 4 turns would get you close on high spd needle settings. but the above settings are the initial factory starting points.
On you other post with your one way, spray it out and check it to see if it slips look at it with a magnifying glass for cracks bfore installing it. once replaced, make sure its installed correctly, trust me it can be easy to make a mistake, if you are not paying attention i speak from experience. The last thing you want is it flying a part inside your engine.
good Luck
