RCU Forums - View Single Post - Weston Magnum Elevator Trim
Old 11-11-2002 | 06:54 PM
Cactus.'s Avatar
Cactus.
Default Weston Magnum Elevator Trim
do you mean it dives, or just flys nose down? check the wing is seated propperly, check the down thrust, is it diving or climbing when you apply power? opposite to power off? i think the locals have a little up, more important is using the elevator halfs to correct any twist when you pull up
