RCU Forums - View Single Post - DA 50R - Carb position reversible?
Old 11-24-2005 | 02:58 PM
zorka
Default RE: DA 50R - Carb position reversible?
Thx Joe,
I did a Carb upgrade myself sometime ago and not sure if I rotated the reed block. Can you check which direction is the fuel line comming out of the reed valve in relation to the cilinder when is in the correct assembled position? Pointing downwards toward the crankshaft or upwards to the spark plug?
