RCU Forums - View Single Post - Eflite Blade CX
Old 11-25-2005 | 08:35 PM
dribbe's Avatar
dribbe
Default RE: Eflite Blade CX
ORIGINAL: Jerryc
Anyone have issues with Pirouetting faster to the left and slower to the right? FIX???
Generally, this is an indication that your rudder trim is off-center.
Put it in the center, and check your yaw rate.
(It will spin faster in the direction that the trim is favoring)
Hint:
-Run about 1 minute off your battery to lower the voltage a bit.
-Next, use the instructions and the mixer on the 4 in 1 to trim the heli for center Tx trim. This should be the best overall trim.
-Sometimes it is best to unplug, and replug the battery after the first minute or so.... to minimize drift.... the biggest change is at the beginning, and end of the battery.
David
