RCU Forums - View Single Post - Eflite Blade CX
Old 11-26-2005 | 12:15 AM
dacaur's Avatar
dacaur
Default RE: Eflite Blade CX
Here is my video of my first flight, to be fair I did have some prior FP experience with a walkera dragonfly #4.
[link=http://www.dacaur.com/vids/bladecxfirstflight.mpg]Video - Blade CX first flight[/link]
The blade CX is VERY easy to fly, as you can see in my video, once you get it trimmed you can fly hands off for around 10 seconds before you have to correct it.
I do have the pirouetting issue, but mine goes faster to the right, I also need full right trim and have to hold some right rudder, I have only flown 2 packs through it, and have been having too much fun to mess with the mix pot, but I bet that will solve it... my only complaint is that the rudder seems to have -expo built in, which is probably great for a total heli/flight newbie, but for someone that has flown heli's or fixed wing planes, it means you have to press the rudder stick further than you think you should have too, something that wouldn't really be a problem once you get used to it i think.... I'm going to try it with my prism 7 and see what I can do about adding some +expo to the rudder and see if that helps....
