RCU Forums - View Single Post - Covering question
Old 11-26-2005 | 03:29 PM
redfox435cat's Avatar
redfox435cat
Default RE: Covering question
I've found the best way to get good curve is on a great planes building board with an exacto knife. It has to be a new blade. Your base color should be ironed on but sovent will work. aditional colors on top of the monokoke should be alpied with solvent. If your having air bubble issues you should go over the suface with a wood pecker. I've found that with a really hot blow gun 99% of air bubbles will go away. My big problem is the schems around control surfaces.
