RCU Forums - View Single Post - Uproar
Thread: Uproar
Old 11-26-2005 | 08:36 PM
freebird1
Default RE: Uproar
Ok
I am all done. Ready to take flight , but the CG is off bad. Julian537, you had this similar set up. Where did you put the battery. The only thing I know to do is put the uproar on a CG machine and move the batter intil I get the correct CG. Then, cut and install the battery in side the fusl. which will be behind the trailing edge of the wing. Help!
