RCU Forums - View Single Post - DA50 Choke connection to servo
Old 11-27-2005 | 05:23 PM
mstroh3961's Avatar
mstroh3961
Default RE: DA50 Choke connection to servo
I just screwed a sullivan ball link to the stock arm. The link that comes with a plastic rod end that locks over a ball. Only drawback to this is the servo endpoint has to be turned way down. It works fine anyway. The other option is to grind off the end of the choke shaft. and remove the stock arm. Replace with a nose wheel stearing arm.
