ORIGINAL: cenracer1
what tabs are you refering about... I did the same upgrade but left the original brake seat... the plastic one.. the brakes work great.. I bonded the pads to the metal backing and used the metal vented rotor.. took a bit of sorting out at first but worked great...
I removed the original brake and just installed the metal vented disk. Should I have left the original brake disk with this new metal vented disk? I still have the part (don't throw anything away, it's a sickness).
The tabs are on the metal brake disk that came with the kit. Thanks.
