RCU Forums - View Single Post - Eflite Blade CX
Old 11-28-2005 | 04:11 AM
  #40
Get Real's Avatar
Get Real
Default RE: Eflite Blade CX
no not suggesting that.. id use there charger after they send you replacment.. i have no idea what your exact specs are on charger you mentioned... best way and safest is to use the white balancer plug/if thats not an option and you want to fly rite away you could pick up a female jst connector and solder it to charge wires on charger. lipos can be very dangerous if not charged properly.. any battery for that matter but more so with lipos. when using a charger with a lipo its very important you charge at proper rate and cell count. if your sure charger you have is lipo compatable and its set properly it should be fine charging through jst connector(its best to use balancer plug though). make sure polarity is rite on connector when you solder it to charger. good luck.
