RCU Forums - View Single Post - Recommended Engine for GP Big Stik 40
Old 11-28-2005 | 06:26 PM
SkyDemon
Default RE: Recommended Engine for GP Big Stik 40
Ed,
I like the pull-pull rudder setup, I think I'll do the same thing since I have read a few reports on here that recommended moving the tail servos to the back. I assume you had to fabricate some kind of servo tray?
What type of brackets do you use for the rudder supports to go with the pushrods?
I also have the Big Stik 60 in a box. I got that first without thinking that since there's not much if any dihedral in the wing, there is no way I could fit it into the back of my Jetta like I can with my NexSTAR wing []. One of my projects for the winter will be putting a hitch on the car and modifying my small utility trailer by adding a hinged cover so I can haul my planes to the field.
Mike
