RE: Throw Meter
I don't recall anyone claiming 1/100 of a degree. The AeroPerfect has 1/20 of a degree resolution or .05 degrees. It's not just for control throws even though the name might imply otherwise. Great for measuring decalage, incidence, engine thrust or any other angle you need to measure on your aircraft (I also like to use it to match wheel pants- buts that's just me). The high resolution and repeatability of the AeroPerfect meter allows modelers to quantify the total amount of backlash in the servo gear train and associated linkages.
zzw26n: I PM'd you. Thanks.
