The only way I can see to do it is to cut away the covering material...sparingly of course. I would cut right on the original cut out...where I put the "filler plate", and cut that whole bay out, and only that bay. That will give you plenty of clearance to do what I did. It will bacically be hidden under the stab, in the shadow anyways. That would be my suggestion, and what I would do if I already had the stab installed. Good luck, and yes, let us know how it goes.
