Enya 45
HI JEFF, I'M HAVING A PROBLEM WITH MY ENYA 45 ,HAS LOTS OF COMPRESSION,STARTS RIGHT OFF TRANSSION IS REAL GOOD THE PROBLEM I'M HAVING IS GETTING IT TO IDLE RIGHT
2900 RPM IS THE LOWEST I CAN GET IT TO IDLE AND STAY RUNNING AT THAT RPM WHEN I PULL BACK ON THE STICK TO SLOW IT DOWN IT JUST DIES OUT RUNNING NEW PLUG A-3 OS
AIR BLEED SET A HALF OF HOLE. THIS IS A OLDER ENGINE BOUGHT IN 1998 OR 99.HAVE CLEANED CARB . WHERE DO I GO NEXT ????? THE ENGINE RUNS TO GOOD ,HAS TO BE CARB.
I FEEL LIKE . ALL HELP APPRECATED THANKS TWOSTROKE47
