RE: HELP PLEASE
Plev What's up man this will be the beginning of many problems for you. check to see if there are any plastic shavings in the gas tank from the factory blocking the fuel line. if that is clear reset the carb to factory setting and try to blow into the exhaust line watching the fuel go into the engine it should go pretty easy if you turn red trying to blow through the line your carb is clogged take it apart and clean it out! hope this helps you out and good luck!!!!
