RCU Forums - View Single Post - Engine Breakin
Old 11-30-2005 | 05:13 PM
Antique's Avatar
Antique
Default RE: Engine Breakin
If you set the needles at the factory setting you may or may not be right...Factory settings are vastly over rated and are set so that the engine will run so rich it can't possibly hurt itself...Setting needles is no big deal, try it, you can't possibly damage anything running it on the ground..It will quickly die if too lean, and four cycle if too rich [8D]
