RCU Forums - View Single Post - Dont Know What the engine is.
Old 11-30-2005 | 05:14 PM
bruce88123
Default RE: Dont Know What the engine is.
The difference is what parts are used.
One engine has a compression ring at the top of the piston and the other does not.
Obviously one will have a groove in the piston for the ring and the other will not. All you have to do is look into the exhaust port to tell.
Bore & stroke may also be different, I did not look. Apparently no need to since you are not answering the questions anyway.
