 Dont Know What the engine is. >
Old 11-29-2005 | 07:06 PM
EtnieSk8r3000's Avatar
Default Dont Know What the engine is.
I know its a O.S Max SF, but i can t find it any where for parts and stuff.HELP....
Old 11-29-2005 | 07:27 PM
exeter_acres's Avatar
Default RE: Dont Know What the engine is.
Wat you talkin 'bout, Willis?
Old 11-29-2005 | 07:49 PM
JohnBuckner's Avatar
The OS SF series engines (great running engines by the way) where replaced by the OS FX series some years back and now it seems the FX's will eventually be replaced by the AX series in the future.
Can,t help you on where to get parts (don,t currently own any of these engines) but someone I,am sure may have some links. It would probably help if you stated exactly what size engine and parts you needed.
John
Old 11-29-2005 | 09:22 PM
If it's an OS 46 SF, LEO 46 Pro parts will fit.
Old 11-30-2005 | 11:11 AM
he just got another engine its a super tigre s61 anyone have any thing about them too thx bye
Old 11-30-2005 | 11:40 AM
the o.s engine is a .40 i only had a sec 1 to look at it yesterday lol
Old 11-30-2005 | 12:31 PM
Here is the OS 40 SF w/ring
http://www.osengines.com/parts/xr15400.html
and w/o ring
http://www.osengines.com/parts/xr15410.html
You still have not said what kind of parts you are looking for. [:@]
get a p/n and look it up at Tower or elsewhere for starters.
Old 11-30-2005 | 04:12 PM
what the differince.like ring or w/ring???? i no more about rc buggys then planes.lol
Old 11-30-2005 | 05:14 PM
The difference is what parts are used.
One engine has a compression ring at the top of the piston and the other does not.
Obviously one will have a groove in the piston for the ring and the other will not. All you have to do is look into the exhaust port to tell.
Bore & stroke may also be different, I did not look. Apparently no need to since you are not answering the questions anyway.
Old 12-05-2005 | 04:57 PM
what kind of gas do each of the engines use.
Old 12-05-2005 | 05:26 PM
No gas. 10-15% nitro model airplane glow fuel from the LHS will be fine.
Old 12-05-2005 | 05:58 PM
chould i use trinity moster horsepower 20%
Old 12-05-2005 | 06:06 PM
Sorry, never heard of that. 20% is on the high side but would work. Do not use car/truck fuel. They have different oil/additives as I understand it and are no0t recommended for plane engines.
