RCU Forums - View Single Post - CAMPAC MEMORY TXFR FM 9C TO 9CS
Old 12-02-2005 | 05:36 AM
Howard
My Feedback: (55)
Default CAMPAC MEMORY TXFR FM 9C TO 9CS
Your support on this forum speaks volumes for customer relations -- thank you. I just purchased a new 9CS with a CAMPAC to replace my 9C and want to transfer six plane in memory from my 9C to the 9CS. I read on the Futaba FAQ page that this will happen if I load the models into the CAMPAC in the 9C and then insert the same CAMPAC into the 9CS. My question is that the memorry locations for the CAMPAC memory in the 9C will be models 9 through 14 and in the 9CS it would be models 13 through 18. Does this mean that when I insert the CAMPAC into the 9CS from the 9C that all six models will be there beginning at location 13 and ending at 18 instead of beginning at 9 and going through 14. If that is not true then it appears to me that I can only transer models in memory locations 13 and 14 - you can see why I ask.
It is also my understanding that you can move the CAMPAC from the 9C to the 9CS but once it is initialized in the 9CS it cannot be used in the 9C - is the correct?
Thank you
Howard Birch
