RE: Junkers type control surfaces?
That type of control surface is from the time when aircraft were getting larger but hydraulic assist (power steering) wasn't yet used. What designers soon moved to is the conventional control surface with the hing line positioned more rearward. Basically the same result but streamlined. You can still find the other type of surface on some modern designs. For example, if I remember right, the experimental KitFlox ultralight used them?
Multiflyer
