RE: carb question
[quote][What does the pink line designate and why does it seem to loop back into the carb? just my attempy at showing the primer bulb.
When running the return line and clunk line in the tank,can they be attached side by side to move together as one assembly or does it matter where the return line is positioned in the tank?I guess,what I mean by that is does the return line have to be immersed in fuel all the time in order for it to work properly(i.e- not suck air?)or can I position it any old place inside the tank?. just remember that you may use that line to drain the tank in addition to use as a fill. I may have the two lines wire-tied in one of the tanks.
/quote]
