RE: carb question
plugging the ouput line downstream of the bulb is IMHO somewhat of a waste. With time the bulb will deteriorate and allow air in to output side of that check valve, the same as an unplugged outlet line. I think that sealing the hole for the rubber check valve might be a more permanent solution.
