RCU Forums - View Single Post - Install the DEPS elevator system in a painted fuse
Old 12-04-2005 | 01:02 AM
KeithB's Avatar
KeithB
Default RE: Install the DEPS elevator system in a painted fuse
I'll play with the idea of the 1/8" CF tube over the 0.07" rod, I just happen to have some of that on hand. Troy, did you just use CA to glue them together or did you use epoxy or JB Weld?
Mike, I already thought about moving the servo back, but even moving it a good six or eight inches back only moves the exit hole back about 1".
Something I was kicking around in the ole nogin was using a larger 3/16" rod so I could move the branch to the 0.07 rods much further back, this would allow an exit much closer to the control horns.
Keith
