RE: Eflite Blade CX
update on flybar part.. i tryed to pop mine off to no avail and felt if i used more force id probally break it and it seemed to be one solid part. i found out that there glued at the factory but replacements come without being glued together. personally if i had to replace mine i would glue replacment.. id rather have it break in a crash than have a chance of it vibrating loose and causing a crash without warning. so manual is correct and production part is same only its glued at factory appearing to be one solid part and shouldnt be able to pop off on out of the box models.
