RE: low end on 4 stroke
If you're still using the glowplug you used to break the engine in with, or if it's not an OS-F type then change plugs now to a brand-new F-type. You'll find that you'll be able to knock 1,000 RPMs off that idle and the engine will handle much better all around.
