low end on 4 stroke
Old 12-04-2005 | 09:07 PM
Gringo Flyer's Avatar
My Feedback: (18)
Default low end on 4 stroke
I have about 1 1/2hours of runtime on a Magnum 91 4S. I followed break in procedures to a T and the engine is a gem.
However, the low end seems to me a little high. The engine is on a 40 sized 3D plane and on the landing approach I have to cut the engine or it wont land!
With a 14X6 MA on 10% the lowest reliable idle I can get is between 3000-3500. I have tweaked the low end needle valve. If I leave the glow starter on it I can get it a little lower.
With less than a gallon through the engine is the high low end just do to the engine needing to be broken in more or is 3000 RPM normal for idle?
Old 12-04-2005 | 09:30 PM
Banned
Default RE: low end on 4 stroke
If you're still using the glowplug you used to break the engine in with, or if it's not an OS-F type then change plugs now to a brand-new F-type. You'll find that you'll be able to knock 1,000 RPMs off that idle and the engine will handle much better all around.
Old 12-04-2005 | 11:09 PM
w8ye's Avatar
My Feedback: (16)
War Eagle,
If you cannot find a OS "F" down there the Y-S four stroke or Hanger 9 Four Stroke Super Plugs work pretty good too.
Enjoy,
Jim
Old 12-04-2005 | 11:42 PM
Well, a .91 spinning a 14 inch prop, pulling around what is likely a 4.5 to 5 lb 40 sized 3d plane will probably not be able to slow down enough to land under power! One of the issues of overpower a plane with such light wing loading a superior lift. Might just have to kill it to land everytime!
However, you should be able to idle down into the 2000's. I have two of these engines, and they all idle pretty low. But, they don't come with a good plug, so change it to a good one--OS F or H9 super plug and you'll notice an instant difference!
Old 12-05-2005 | 06:05 AM
And the simple solution for most a/c that are too fast to land with the engine at idle is to put a prop on that engine with less pitch. That works great no matter what the power loading.
Most times, you'll never even notice a change in the top speed.
I've got a couple of .40 size models with powerful .46s on them. First thing I did was swap out the 6 inch pitch props that were the recommended ones, and bolt on 5 inch pitch. Granted, for one a/c, I had to cut down a 12x5 to keep enough blade to keep the engine warm enough, but the a/c lands at a fast walk now. Having more fan area is one of the best air brakes available, but only works if the pitch is low enough.
