RCU Forums - View Single Post - Multiplex Magister RTF
Old 12-06-2005 | 11:24 AM
  #121
Greg Covey's Avatar
Greg Covey
Default RE: Multiplex Magister RTF
The parts recommended for the spinner and prop adapter did not play well for me so I used a different 5mm prop adapter I had on hand. The adapter and prop could be used but not with the spinner. We are currently sorting this issue out at Hobby Lobby as they claim otherwise.
I measured 30amps and 300 watts at full throttle. This is good power and can be left at full throttle the entire flight without hurting any of the components. It also allows for the possibility of using a 13" prop, if desired.
I hope to test fly it today if the wind cooperates.
ID:	365876   Click image for larger version
ID:	365877   Click image for larger version
