RCU Forums - View Single Post - Install the DEPS elevator system in a painted fuse
Thread
12-07-2005 | 03:10 AM
30
KeithB
My Feedback: (
1
Jan 2002
630
Garland, TX
RE: Install the DEPS elevator system in a painted fuse
I wanted to share a technique I came up with to help determine where the exit holes should be on the fuse.
In pattern planes I’ve installed three pull-pull rudders and one pull-pull elevator. I’ve been able to reliably determine where the exit holes should be top to bottom, using a similar method to Troy’s above, however, I can never reliably determine where the exit holes should be in the front to back dimension. Above Troy demonstrates a method he uses with a ruler and eyeballs. Well, for some reason I can do this five times in a row and get three to four different results. This has to do with the angle at which I look at the ruler in reference to the fuse.
So I got to thinking, how can I make sure I’m looking at the correct angle? There’s got to be some way to measure this.
That’s when I realized that a string between the two end points, elevated above the fuse, and a square was the solution.
Hopefully the pictures below will be sufficient to explain the technique.
Keith B
Reply
Like
KeithB
View Public Profile
Send a private message to KeithB
Find More Posts by KeithB
View iTrader Profile
