RE: Does anyone else have this problem?
Try priming it, and if you've already done that, check your idle setting. The hole in your carb should be about 1mm in width when you're not braking or accelerating. Your idle screw to adjust this is the little one near the base of the carb.
BTW: 200th Post!! WOOOO!
