Can of worms...
Hi,
Information on reynoulds numbers can be found in the aerodynamic forum...the problem is you can't realy simplify their explanation without loosing its meaning so be prepared for some heavy reading!!
If you build the model light you can always add a bigger battery etc (or 2 ) if need be!!..i doubt being under weight will be a problem!!
Have fun
