RCU Forums - View Single Post - Skylab wing dimensions?
Old 12-09-2005 | 01:50 AM
McLeodAviation's Avatar
McLeodAviation
My Feedback: (70)
Default RE: Skylab wing dimensions?
Hi Kris,
Here is a few details off the Skylab box,
"The wings have 3 degrees negative rake vee design"
Wingspan 1660 mm
Wing Profile NACA 0015
The plan only shows one wing panel and a couple inches of the other. The trailing edges are in a straight line with each other. On the plan the trailing edge is not swept back. The pictures on the box certainly look like the wing is a little swept back! The leading edge tappers 4 inches. The root chord is 12" and the tip is 8".
Shown on plan the anhedral {Unterlange fuer Endrippe} is exactly 2 cm or about 3/4 inch at the tip.
Unfortunately my kit is missing the instructions. Maybe I can get a copy from Hegi.
Mike
ID:	367263   Click image for larger version
ID:	367264   Click image for larger version
ID:	367265   Click image for larger version
