RCU Forums - View Single Post - DIY STEEL MUFFLER
Old 12-10-2005 | 08:56 AM
teddywilk
My Feedback: (10)
Default DIY STEEL MUFFLER
(1) grind the crimp around the outside edge until it falls into 2 pieces (2)baffle and standoffs will fall out then remove screeen and insulation, grind off the spotwelds.(3)cut 2 halfs as in pic1 (4)cut off .525 from standoff length pic2. (5)get a piece for the side and cut to shape. i used a case from a junk cd drive. pic3 (6) cut out the pipe and grind it round so u have a flange around the pipe for soldiering pic4 (7)silver soldier the 4pcs together, dont forget to put in the baffle and standoffs inside first! i used a white paste flux and small dia silver soldier. i cant believe it myself but i used a burnzimatic torch for the heat.(8) bolt it to your new toro conversion pic6. im not to sure bout the pipe dia. but it worked for toro so ill try it. it weights in at just ove 3oz
p.s. FOR ALL YOU SECRITARIES OUT THERE I LEFT MY CAPS LOCK OFF BUT NOW I CAN READ WHAT I WROTE CAUSE IM HALF BLIND AND IM TALKIN SO QUITE I CANT HEAR WHAT IM SAYIN CAUSE IM MOSTLY DEAF.
FARMER TED
ID:	367746   Click image for larger version
ID:	367747   Click image for larger version
ID:	367748   Click image for larger version
ID:	367749   Click image for larger version
ID:	367750   Click image for larger version
