RE: RAM 1000 Problems
Hi Reuben. You have not stated what the number in the lower left corner of the display reads. The 250 level is the minimum amplitude of the rpm sensor signal. The C03/T03 software runs the engine up to 5K RPM the first time without igniting to make sure the sensor is putting a good signal out before trying to start the engine. What reading do you get with the rpm at about 5K RPM??. Report back please. You should get a reading of at least 250 with the 1000 and even greater with the 500 unless you have a marginal magnet in the nut or a marginal sensor. I need to know what the sensol level reading is and I may have a way of increasung the gain of the sensor amplifier in the ECU. I have never had to do that in the past. Later. Bob.
