RE: Futaba 9C Radio
someone was asking about the 9c compared to the 9cs the 9cs has all the features of the 9c plus more model memery and according to futaba website as follows :
Enhancements to all three modes!
Glider Mode
In addition to the Basic offset trim, the 9C Super offers three other offsets (launch, thermal and speed), with camber that can be customized for each.
The four camber mixes can be set up on one screen and programmed to any of the variable dials.
Besides setup ease, the glider mode boasts much more built-in flexibility.
A new G2F-C mix has been added to the G1FLP and G2FLP mixes.
Airplane Mode
The gyro system can be set up for 2-rate (up/down) or 3-rate (up/center/down) with the GYA gyros. It can also be programmed to any switch for normal or AVCS modes.
The Air Brake is now switch-selectable.
Both the Airplane and Glider Modes feature 7 programmable mixes: 5 linear mixes and two 5-point curves.
Heli Mode
5-point Throttle Curve and Pitch Curve now feature a delay that makes for a smoother transition from hover to idle-up and better control.
The throttle hold and idle-up can be assigned to any switch that feels more comfortable for the pilot.
Hi/Low Pitch can be utilized to adjust the curves on the high side and low side for each flight condition.
Choose from six heli mixes: SWH1, SWH2, SR3, SN3, SWH4 and the new SWH3, along with two linear circuits and one 5-point curve.
