RE: RAM 1000 Problems
"Try this: if you can smell the gas, then go ahead and use a propane torch to light the gas at the exhaust on a test bench. It will not solve your starting issues, but at least you can see if it runs. "
Hi Mark. You can not start the engine if you fail the sensor signal low test even with a torch. Bob.
