RE: Pls share pic of your servo/throttle linkage on G26 or similar
RTK
That big servo arm on your carb, I take it that is your choke? How you access it for starting or you just cut a hole in your cowl and poke your finger to flip it? So with that conversion, your throttle linkage on the same side as choke lever?
And Thanks to all others for the great input and sharing thus far.
