ORIGINAL: butlern
The thrusts were probably built into the plane during the construction. Is this not the case? Did you build the plane, or is it an ARF, or did you buy it already built-up? Generally you can look at the plane from above and from the side to see if there's a few degrees of thrust built into the fuse/firewall.
the plane was an electric originally made for a 15 glow, it was given to me as an electric, Im turning it back to glow it needs the power and lightness I have to reconstruct a fire wall, Thanks any pointers on average thrusts for this type of war bird, so far its 2 deg side 0 down
