spitfire down and side thrust?
My Feedback: (15)
The thrusts were probably built into the plane during the construction. Is this not the case? Did you build the plane, or is it an ARF, or did you buy it already built-up? Generally you can look at the plane from above and from the side to see if there's a few degrees of thrust built into the fuse/firewall.
My Feedback: (7)
ORIGINAL: butlern
