RCU Forums - View Single Post - Help is all of this stuff compatable
Old 12-13-2005 | 02:32 PM
Rocketman612's Avatar
Rocketman612
My Feedback: (85)
Default RE: Help is all of this stuff compatable
ORIGINAL: Dan767
I can't rememember if the transmitter you have is PCM/PPM or just PPM. Be sure that it's PPM. If you are currently running in PCM and switch to PPM, you must cycle the transmitter off and then back on.
Dan,
I did make sure I was on PPM. Will try and get a 4.8v battery out of another plane tonight to check the Rx without the ESC connected.
Pete
