Engine trouble!
Hi bdxhad,after each flying day you should disconnect or plug off the fuel line to the carb,then connect the igniter to the glow plug and spin over the engine until all the fuel is burned from the engine,after the fuel is out of the engine then add a dozen or more drops of some type of afterrun oil,if not the engine will gum up and the bearings will rust,the engine will have a short life.
